Platform
Platform
Topics related to optiSLang, HPC, DesignXplorer, Cloud and more.
Different initial temperature conditions for two different object in transient-thermal
    • AdhityaKrishnan
      I am facing a problem in initializing different initial temperature for two different objects in ansys transient thermal. Can anyone suggest a method to proceed? Thanks for the help in advance
    • jj77
      What do you mean by different objects - can you add a screen shots of your wb project and details - the more info the easier for us to give feedback.
       If you mean how to set different reference temp. for different parts, then under details of the part and definition, set reference temp. option to by body and then type in the ref. temp. for that body, see below:
    • AdhityaKrishnan
      I would like to set different Initial Temperatures for the inner and outer box for the transient state thermal problem.
    • AdhityaKrishnan
      I found the solution to this problem.
      Create a named selection of the entity that you want to initialize. BODY1
      Create a command in the analysis : IC,NODE,LAB,VALUE,VALUE1,VALUE2,NEND,NINL
      NODE: Select the named selection :BODY1
      Lab : TEMP
      Value: 300
      Ex.: IC,BODY1,TEMP,300
      Run the program.
  • The topic ‘Different initial temperature conditions for two different object in transient-thermal’ is closed to new replies.
