September 10, 2024 at 1:25 pm
September 12, 2024 at 12:29 pm
Rahul
Ansys EmployeeBoth are used to identify the regions where the transfer of loads to and from external fluid solvers CFX or Fluent occurs.
Refer user guide to know more about it.
Fluid Solid Interface (ansys.com)
System Coupling Region (ansys.com)You can use either of them, but using System Coupling Region is recommended.Â
You should select the faces of the geometry that form the interface between the structural model and the fluid model. Refer tutorial to get more clarity on this: Create the System Coupling Region (ansys.com)
1582
1386
1242
