June 23, 2023 at 3:41 pm
June 27, 2023 at 4:27 pm
VJ
Ansys EmployeeCan you compare if the hostID listed in the first line of the license file matches one of the output values from "Get System HostID Info" in the License Manager?
June 27, 2023 at 8:10 pm
June 28, 2023 at 11:50 am
randyk
Forum ModeratorI suspect if you run the followoing, it will result in failure:Â /InstallPath/shared_files/linx64/lmutil -vÂ
Please install Linux Standard Base (LSB) package.
Search ANSYS Help for: Required Linux Libraries and Packages by Producthttps://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v231/en/installation/unix_platform_libraries.html
thanks
Randy-
June 28, 2023 at 2:16 pm
jaguirre
SubscriberThank you, I will try that. In the meantime, is it necessary to download the Enterprise License Manager for Linux, or will the Ansys License Manager install and run fine on Linux?Â
- The topic ‘Did not upload file: Error: the hostid in the licesne file is not a valid…..’ is closed to new replies.
5849
