March 11, 2024 at 5:40 amsrikant gvSubscriber
How battery electrochemistry models(ECM,NTGK & Newman P2D ) & battery solution models (Circuit network method,CHT coupling,MSMD ) depend on quality of mesh...? Is there any criteria of Mesh which is preferred ?
March 18, 2024 at 2:44 pmMurari IyengarAnsys Employee
There is no specific type of mesh as it depends on the geometry, complexity, resources available, etc. If you are looking for an example, please see the battery tutorial in the Ansys Help Manual Fluent Tutorials (ansys.com)
- The topic ‘Dependency of Battery solution Models on Meshing’ is closed to new replies.
Ansys Innovation Space
- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Fluent fails with Intel MPI protocol on 2 nodes
- Cyclone (Stairmand) simulation using RSM
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
- convergence issue for transonic flow
630
599
591
366
