July 28, 2021 at 10:05 amAmourSubscriberJuly 28, 2021 at 10:18 amErik KostsonAnsys EmployeeHI
Also try a modal analysis of the structure with the same boundary condition (say fixed) and see that all parts are connected (so that there are no 0 Hz rigid body modes). In that way we will know that all parts are connected as it should.
Thank you
Erik
Viewing 1 reply thread- The topic ‘Deformations are not transmitted correctly’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Problem with access to session files
- Ayuda con Error: “Unable to access the source: EngineeringData”
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- Geometric stiffness matrix for solid elements
- How to apply Compression-only Support?
- How to select the interface delamination surface of a laminate?
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- SMART crack under fatigue conditions, different crack sizes can’t growth
Top Contributors-
1216
543
523
225
209
Top Rated Tags© 2024 Copyright ANSYS, Inc. All rights reserved.
