Define thermal contact conductance as parameters with ANSYS Mechanical
    • ssequeira9
      In ANSYS Mechanical, heat transfer coefficient for convection can be defined as parameters as shown in the Figure below:
      Heat transfer coefficient parameter
      I would like to do the same thing with Manually defined thermal contact conductance within the Connection section. However, the option of parameter definition "P" is not proposed (see second Figure below).
      Thermal contact conductance
      Is there any way to define this thermal contact conductance as a parameter?
      Thank you in advance.
      Sebastien
Viewing 0 reply threads
  • The topic ‘Define thermal contact conductance as parameters with ANSYS Mechanical’ is closed to new replies.
