September 27, 2017 at 11:19 am
admin
Ansys EmployeeThe way to define a string in a journal file is as follows: (define filename "sample1") (ti-menu-load-string (string-append "file read-c sample1.msh")) With the above command, you can read the mesh file defined with sample1.
admin
Ansys EmployeeHow do I define a string in a journal file?
- The topic ‘Define a string in a journal file’ is closed to new replies.
1306
