Electronics
Electronics
DC Conduction Analysis Example
    • buddapatni
      I'm walking through the Maxwell 3D - DC conduction solver examples given by Ansys. This is featured on page 540 of the Maxwell 3D user guide, an example for which there's also a youtube tutorial.
      I'm able to follow the example just fine until the point of the calculation. When I evaluate the integration, I get the above error. "No field solution at the selected design variation" . I see the same issue with both 2018 and 2019 versions of AED. Please advise, thanks so much.
    • buddapatni
      Solved. For anyone who runs into this problem, after setting up analysis, automatically titled "Setup1", you need to right-click and select "analyze" in order to calculate this value.
    • buddapatni
       Solved. After creating analysis, which is automatically titled "Setup1", you need to right-click that and select "analyze" in order to evaluate anything using the calculator.
  • The topic ‘DC Conduction Analysis Example’ is closed to new replies.
