February 22, 2024 at 10:52 amBALAMUGESH MSubscriber
hi all,
i need to know, if i put constants from th APDL to Creep model and simulate, there is conergence issue at the begining of the creep stage on, what will be the problem what i need to focus to avoid this convergenc issue
February 22, 2024 at 11:09 ampeteroznewmanSubscriber
One thing to focus on is to use sufficiently small time steps at the beginning of the simulation.
February 22, 2024 at 11:13 amBALAMUGESH MSubscriber
i have used only two time steps sub steps like 100, 100, 1000. it is not converging failure at the begning itself
February 22, 2024 at 10:43 pmpeteroznewmanSubscriber
What is your end time? Let's say it is 65,536 seconds. That is 4^8.
Use 8 steps with end times of 4, 16, 64, 256, 1024, 4,096, 16,384, 65536.
I expect if Step 1 has an end time of 4 seconds and you give it 100 initial substeps, it will converge. If it does not, there is something wrong with your model.
February 23, 2024 at 5:40 amBALAMUGESH MSubscriber
- The topic ‘creep convergence issue’ is closed to new replies.
1882
802
599
591
366
