February 28, 2023 at 6:30 am
Tin joksumnak
SubscriberHello all, I am a student working on my project.
I'm trying to do the ansys static analysis on my assembly and it's showing some errors. I have used the mesh with Method> Tetrahedrons>Patch independent Then i used the min size = 25mm for the both side of frameÂ
And the mesh statistics Nodes= 375725 and Elements = 219663 then I insert the load and supports like this
aThen put some solution > Deformation and stress but it couldn't solve due to 2 warnings and 1 error "An unknown error occurred during solution. Â Check the Solver Output on the Solution Information object for possible causes." then i checkout the solver output to find possible causes.but I don't understand it.
February 28, 2023 at 7:06 am
ErKo
Ansys EmployeeHi
See the error it says what you should try and modify an improve.
All the best
Erik
February 28, 2023 at 2:18 pm
Rahul Kumbhar
Ansys EmployeeIn Mechanical, at the top toolbar, there is Selection tab. use Mesh by ID option under selection tab and enter the element number in the error message. This will highlihgt the element. You can just remesh that body with better mesh.
February 28, 2023 at 2:29 pm
Tin joksumnak
SubscriberI will try thank you.
Thanks
February 28, 2023 at 2:28 pm
Tin joksumnak
SubscriberÂ
- The topic ‘Couldn’t solve the solution. Static structural problem’ is closed to new replies.
5849
