May 3, 2024 at 8:36 am
chuminhkhue
SubscriberHi, everybody.
I'm doing in ansys fluent 2023R2.
-Â Steady-state for 2D model.- Multiphase model: Eulerian.- Primary phase material: Newtonian.- Second phase material: non-Newtonian.-Â Scheme: phase coupled simple
-Â Mesh size: 5e-3mm.
-Â Diameter for secondary phase: 8e-3mm.
-Â Momentum is second-order upwind.
Boundary condition: rectagular (0.1 mm and 20mm ), velocity inlet is 0.5m/s. zero presure at outletMy model cannot converge when using Schiller-Naumann model for Drag Coefficient and saffman-mei for Lift Coefficient. If Lift Coefficient and Drag Coefficient are constant, then it can converge with the default criteria.
I am looking forward help from experts and knowledgeable users
Thank you so much!!! -
May 3, 2024 at 9:09 am
Forum ModeratorHave a look at the flow field - what's going on? Multiphase models rarely run well in steady state as there are nearly always some transient features in the flow. How are the monitors looking?
May 3, 2024 at 9:20 am
May 3, 2024 at 10:02 am
Forum ModeratorPoint monitors from the report definitions - ie how the flow is behaving in the domain.Â
May 3, 2024 at 10:42 am
May 3, 2024 at 11:56 am
Forum ModeratorNo worries. You may find you want single point values in various locations to get a better idea of what is going on.Â
Of the above, the Lift plot looks most diagnostic as the scale is reasonable (you can alter the scale and number type in the plots). That suggests the solution isn't stable, and that something is changing with each iteration. You now need to review more data points, mass reports and a mix of contour & vector plots at intervals to decide if the result is good enough to answer the question the model was built to solve.Â
May 9, 2024 at 10:25 am
May 9, 2024 at 10:29 am
Forum ModeratorChange the scale on the xy plots - there may well be some noise that's being masked by the nonsense values from the first 50-100 iterations. That may well explain what's going on.Â
May 9, 2024 at 11:08 am
May 9, 2024 at 12:12 pm
Forum ModeratorSo the solution is still changing, and may have some transient features. Run on and see what happens. Also save some contours etc to see if the flow field changes.Â
- The topic ‘Converge issue with phase interaction’ is closed to new replies.
5734
