September 12, 2023 at 1:47 amAwang Shahariffin Bin Awang KechilSubscriber
Hi All,Â
I want to model an O-ring that has free play with neigbouring parts. How can I setup the contacts for parts that has free play? Thank you.
September 12, 2023 at 6:07 amAkshay ManiyarAnsys Employee
Hi Awang,
Can you share the screenshot of the geometry? Meanwhile please check the below video from Ansys learning courses.
Analysis of an O-ring Seal — Lesson 3 - ANSYS Innovation CoursesÂ
Thanks,
Akshay Maniyar
- The topic ‘Contact Settings’ is closed to new replies.
Ansys Innovation Space
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- Frictional No separation contact
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- Script Error Code:800a000d
- Elastic limit load, Elastic-plastic limit load
- Element has excessive thickness change, distortion, is turning inside out
599
591
565
366
