September 23, 2024 at 4:16 pm
vamsinaik_p210043ce
SubscriberHow to get particle particle interaction in ansys rocky, i.e., contact forced between the particles?? Is it possible to get force chain daigaram (Force chain is solid lines that illustrate the contact force transmitted between different elements)?
September 25, 2024 at 1:42 pm
Lucas Bertollo Baggio
Ansys EmployeeHello,Â
You can Enable Contacts Data by selecting Contacts in Data Panel and enabling its checkbox in Data Editors.Â
In the postprocessing, you can open a 3D View, go to Contacts | Coloring tab and enable Contacts Network (force chain).
best regards,
Lucas
October 1, 2024 at 5:27 am
vamsinaik_p210043ce
SubscriberThank you sir for the reply
Now, I am able to get contact forces (as normal and tangential forces) from the contacts tab, which is very useful for my research.
May I know the role of the Numerical Softening Factor in ansys rocky? As I increase the value of the Numerical Softening Factor from 1 to 1.5, more contact forces are generated in NSF 1.5 compared to 1.Â
5639
1885
1403
1303
