May 16, 2024 at 8:51 pm
Fady Elshazly
SubscriberHello,
can I use *CONSTRAINED_LAGRANGE_IN_SOLID to constrain beam in solid? will this constrain the beam rotational DOFs to be zeros following the solid?
knowing that the beam nodes are atop the solid surface and the beam elements are not penetrating the solid
Thanks
May 17, 2024 at 2:43 pm
Ushnish Basu
Ansys EmployeeTry CONTACT_TIED_SHELL_EDGE_TO_SURFACE_BEAM_OFFSET
May 17, 2024 at 4:06 pm
Ian Do
Ansys EmployeeHi Fady,
You may also try *CONSTRAINED_BEAM_IN_SOLID .
Ian Do
- The topic ‘*CONSTRAINED_LAGRANGE_IN_SOLID LS-Dyna’ is closed to new replies.
