January 12, 2023 at 8:36 pm
kg
SubscriberIs there a way to obtain and export the complex radiation pattern of an antenna to a file?
February 7, 2023 at 6:29 pm
Praneeth
Ansys EmployeeHi kg,
Thank you for reaching out to us and we appreciate your patience.
It is possible to export the complex radiation pattern of an antenna. Right mouse click on the defined infinite sphere under "radiation" category and select “compute antenna parameters”. You will find “export fields”. Use any of the FFD or CSV formats.
Best regards,
Praneeth. -
February 7, 2023 at 6:31 pm
Praneeth
Ansys EmployeeHi Kasseyy,
It looks like your reply does not match the context of the original thread. Please check once.
Best regards,
Praneeth.
- The topic ‘Complex Radiation Pattern’ is closed to new replies.
