August 14, 2020 at 9:54 pm
vigneshg
SubscriberHello,nI am facing this error for quite a few days with ansys maxwell transient simulation nEngine terminated unexpectedlyn[warning] Com Engine non-responsive since time and date. Can be due to CPU intensive processing or network problems. If persisting for long, manually kill the com engine process and restart analysis. Retrying..... n[error] Machine Local Machine: Engine terminated unexpectedly, or machine reported error or was inaccessible. nThis is even occurring with file which worked perfectly fine earlier. I am sure there is no CPU intensive processing. There is no license server/ network issue to my knowledge. nAny help would be appreciated.nThanks nVigneshn -
August 20, 2020 at 12:34 pm
icellb1
Ansys EmployeeHi, Vignesh,nUsually too fine mesh can cause this problem. However, since you mentioned this error even occurs with file which worked perfectly fine earlier, could you check your disk space - If your hard drive is almost full? If none of these work, we may need to pass this question to app developers.n -
March 14, 2023 at 8:19 am
ngoctm
SubscriberHi icellb1, Is there a solution to this problem?
March 14, 2023 at 3:07 pm
li liu
SubscriberI think you should save and close software. then re-open software. I do that ,then it works when I meet this issure.
March 15, 2023 at 2:18 am
ngoctm
SubscriberThank you, I was advised the same, but not on my machine. I hope there is a solution from Ansys.
Viewing 4 reply threads
- The topic ‘Com Engine non-responsive’ is closed to new replies.
1306
