April 20, 2022 at 6:55 am
arindam.rs.iiests
SubscriberMy models contain element-by-element density and Young's modulus which I input through command. I want to colour plot the material variation in Workbench but am unable to achieve that. How can I do that ?? Thanks in advance.
P.S. I am using ANSYS 2019R2.
April 20, 2022 at 12:23 pmAkshay Maniyar
Have you tried to use material plot option? Please check the Ansys help link, for more details.
Thanks Amaniyar
April 21, 2022 at 7:50 amarindam.rs.iiests
SubscriberThank you for your response.
I did give the material plot option a try with no results.
I am adding a 'Commands' object under 'Static Structural' which, I learnt, replaces the previously assigned isotropic material with the commands before solving. I added the 'Commands' object under the 'geometry' too which also did not generate the required material plot.
Is there any other way to plot the material??
April 25, 2022 at 11:28 amAkshay Maniyar
Can you share the image of command snippet which you are using?
Thanks Amaniyar
April 29, 2022 at 7:03 amViewing 4 reply threads- The topic ‘Colour plot of material property in Workbench’ is closed to new replies.
