Electronics
Electronics
Cogging torque and torque ripple
    • VivekKamble
      Is cogging torque and torque ripple same in a PMSM?
    • Charlotte Blair
       No,  Torque ripple arises due to imperfect commutation of the phase currents, Ripple introduced in the current waveform due to chopping and due to reluctance variation, due to slotting, in the magnetic circuit as the rotor rotates which is called cogging. So, Cogging is a part of torque ripple and torque ripple is a combined effect of many factors.
    • Navya Chode
      You can feel the cogging torque when you rotate the motor shaft with your hand. Whereas the effects of imperfect commutation and current ripple cannot be detected in this way.
  • The topic ‘Cogging torque and torque ripple’ is closed to new replies.
