April 23, 2021 at 8:30 am
jwiesemann
SubscriberHi everyone, nI'm trying to change the delay time of a delay-block using an NDTAB-type lookup-table. n
In the configuration of the delay block, I use the variable t_delay:n
When I run the simulation, the delay time seems to be right according to the graph. However, the corrent delay time does not seem to be utilized by the delay block.n
The delay time should be 2 ms, but 1.25 ms are realized (the default value I put when creating the variable.n I assume that the variables used in the NDTAB and the delay block are not compatible. Is there any way to cast the variables?.Best regards, nJuliusnn
April 23, 2021 at 12:38 pm
Praneeth
Ansys EmployeeHi Array,
Thank you for reaching to us.
Please provide the name of Ansys tool that you are using and its version to help us serve you better.
All the very best.
April 23, 2021 at 12:40 pm
jwiesemann
SubscriberHi Array ,
I am using Simplorer in Ansys Electronics Desktop 2021 R1.
Best regards,
Julius
May 3, 2021 at 11:52 am
Navya Chode
Forum ModeratorHi,
I am suspecting if simulation step time in TR is much larger to catch the 2ms delay time.
can you check by increasing the delay time?
Navya
- The topic ‘Changing the time of a delay-block using a lookup-table’ is closed to new replies.
