July 28, 2023 at 4:43 am
Naresh Jogi
SubscriberHello, Need help. I am doing a structural analysis. Initially, I was considering A-36 as the structural steel but now I changed it to A-992. I thought A-992 is much stronger but in the results, I do see the same results for both materials. Can anyone guide me?
Thank you -
July 28, 2023 at 8:15 am
Sahil Sura
Ansys EmployeeÂ
Hello Naresh Jogi,
The material properties mainly affecting the results of the linear elastic static structural analyses can be the Modulus of Elasticity (which plays a key role in assessing the stiffness) and Poisson’s Ratio. The Tensile Yield Strength also plays a key role when determining the safety factor, but this does not affect the calculation of stress and deformation.
So if checked via Ansys Material Library, Structural Steel ASTM A992 has a Young’s Modulus of 2.1239e+05 MPa at 23 Degrees Celcius, while from the other sources for the same conditions, Structural Steel ASTM A 36 has a Young’s Modulus of 1.9994e+05 MPa. So if noticed the difference in Young’s Modulus, there must be a very minor deviation observed in the results.
Thus considering this the results should vary to a certain extent. These FEA algorithms are based on numerical methods and thus have limitations; accuracy can be compromised as per the application to a certain extent and thus is up to the user.
A simple hand calculation would also help in addressing the difference observed in the results, which can be a great baseline for comparison.
The solution to the problem can be -
Re-verifying the material properties from physical testing
Turning on Large Deflection to capture better plasticity effectsÂ
Refining the mesh and checking the boundary conditionsHope this helps!
Thanks,
Sahil
/forum/forums/topic/guidelines-for-posting-on-ansys-learning-forum/#latest
July 28, 2023 at 11:48 am
Naresh Jogi
SubscriberThank you, Sahil. This helps.Â
- The topic ‘Changing Steel Material from A36 to A992’ is closed to new replies.
4678
1565
1386
1241
