February 6, 2021 at 11:08 amAnshulSubscriberHi all,nI am simulating a reforming reaction in 2D-axisymmetric case. While putting velocity inlet condition, I am specifying the concentration of inlet species. Say for example. 0.47 for methanol. But as I run the simulation, and get convergence ( less than 10e-05), it seems that the boundary condition of species is changed.nHow this is possible as boundary condition should remain same as given by user. I also monitor the mole fraction of methanol while running calculation, it seems to drop sudden at start from 0.47 to 0.29 etc..nHowever, if I increased the inlet velocity then this change is decreasing. I am not understanding why this is happening?nAlso, for pressure outlet condition, I have put 0 value for the species. Is it happening due to reverse flow?nPlease help me with this.nnAnshuln
February 8, 2021 at 12:05 pmRobForum ModeratorThe boundary condition should be respected, and if you do a surface report what do you see? Similarly plot volume fraction on the inlet only with node values off and local range. n
November 14, 2023 at 9:27 am164170007Subscriber
I also had the same problem and checked the mass weighted average values at the inlet of species despite giving boundary conditions at the inlet. To make it correct we have to mark “Inlet diffusion” in the species transport model, because as soon as species enters reaction starts.
- The topic ‘Change of boundary condition value (mole fraction) of species after convergence’ is closed to new replies.
Ansys Innovation Space
- Non-Intersected faces found for matching interface periodic-walls
- Fluent fails with Intel MPI protocol on 2 nodes
- Cyclone (Stairmand) simulation using RSM
- error udf
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
- UDF, Fluent: Access count of iterations for “Steady Statistics”
599
591
555
366
