April 25, 2024 at 5:28 pm
mmoham65
SubscriberHello,
I have a question about using Rocky. I have fine water droplets around 5 micrometers in my domain which I consider use two way coupling model (CFD-Rocky) . I am wondering if it is possible to define evaporating/condensation (mass transfer) features in Rocky for droplet particles.
April 26, 2024 at 9:05 am
Forum ModeratorIt may be available via a coded API, I'd need to check. Are you looking at particle coating? Just checking that you actually need Rocky and wouldn't be better off with the Fluent CFD solver.Â
April 26, 2024 at 4:01 pm
mmoham65
SubscriberThanks for your reply.
Actually, it's not a coating case. The droplets being emitted, evaporate naturally because they are water particles in a humid room environment.
The conventional DPM model in Fluent assumes no particle-particle interaction. However, since there is noticeable interaction between particles, the DPM model fails to accurately track them.
April 29, 2024 at 9:57 am
Forum ModeratorAt 5 microns and shrinking I'm surprised the droplets do anything other than follow the gas flow.Â
- The topic ‘CFD-Rocky, Particle Evaporation’ is closed to new replies.
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
4597
1495
1386
1209
