July 12, 2024 at 6:28 am
JooJaehoon
SubscriberHello
I want to show result(stress, strain, deformation etc.) contour in specifice surface, so I define xy-plane using 'construction geometry' and set result scope xy plane.
but, I result can't be shown result as I wanted with error showing second picture
What means of that error and how can I solve this result?
first picture is about setting xy-plane
July 13, 2024 at 3:21 am
mjmiddle
Ansys EmployeeIt's a warning, not an error. You should still be seeing a stress contour on the construction surface. It may be a systems issue if the contour doesn't show. Are you remote displaying? Maybe you should update the graphics driver. The result legend seems to think it's displaying something. If you zoom in close, do you see anything?
The warning just means you have shared topology bodies, and results displayed might be from one body or the other. You should probably go to "file > Options > Results" in Mechanical and turn on "Average Across Bodies." Or select one body at a time in the Details of the result,
July 16, 2024 at 3:52 am
JooJaehoon
SubscriberHello, thank you for reply
I'll try your suggestion.
- The topic ‘Can’t showing contour at specific surface’ is closed to new replies.
5799
