Can’t apply bearing load to inside surface of rotor
    • ah05085
      I'm having trouble doing a bearing load simulation. I can't apply the load to my inner rotor diameter surface.
      nPerhaps Bearing Load only works when you have a complete cylindrical hole. You have a half cylinder. Try it with a complete cylindrical hole.n
    • ah05085
      Thats what i did 1st. Do you think the body has to be 1 entity without many faces?n
  • The topic ‘Can’t apply bearing load to inside surface of rotor’ is closed to new replies.
