Ansys Products
Ansys Products
cannot open ensight of ansys19.0
    • luckfan
      I tried to install Ansys many times include 19.0 and 19.2,also installed separately, but I always couldn't open the Ensight module.When I clicked Ensight there with a Flashing blank command box,then nothing happens.When I clicked envision,there are the following tips in attached pictures.I really hope to get someone's help.Thank you!
      Please put the images in with the text: staff are not permitted to open/download attachments. I'm not sure when Ensight was bundled into Ansys, so also check the licence file.
    • luckfan
      Very grateful for your help!
      I know that some users install it with the same steps, but they can be opened, but I ca n’t, is it a problem with my computer?
      The Ensight did not respond at all, so I opened Envision with the following prompt:
      This is EnVision 10.2.3(b) (12/21/2017) build: 55095 ANSYS_R19
      Running on computer: DESKTOP-P75EHBF
      getenv(CEI_HOME) returned [C:Program FilesANSYS Incv190CEIbin..]
      Couldn't find a valid slim8.key license file in the standard
      locations. Please check your environment variables as indicated in the
      Getting Started manual and make sure you have a valid slim8.key license
      file installed and that slimd8 is running if using a floating license.
      Using ANSYS licensing
      Setting Python Home to C:Program FilesANSYS Incv190CEIbin..apex32machineswin64Python-2.7.11
      Python interpreter started (2.7.11 (default, May 24 2016, 17:06:05) [MSC v.1800 64 bit (AMD64)])
      ****************** EnVision Console window ******************
      DO NOT CLOSE THIS WINDOW; it will terminate your application!
      hostname = [DESKTOP-P75EHBF]
      architecture = [win64]
      calling license_info()
      Failed to load resource icon:
      No 3D input device available.
      Detected 4 CPU core(s)
      ensight102.client using 1 thread(s).
    • tsiriaks
      Do you have ANSYS Ensight license hosted with the ANSYS License Manager on a license server ? Please show the content of the license file installed on there.
      If you are using the legacy Ensight license, that will need certain people to help you.
      Thanks,
      Win
    • luckfan
      Win,
      Is this the license you said? The 19.0 version I installed could not find the  ANSYS License Manager  you said. I put what I found in the attached picture.
      Thanks,
      luckfan
    • tsiriaks
      Sorry, could you re-post your image again, it doesn't show up correctly
      Thanks,
      Win
    • luckfan
      This is the image!
      Thanks,
      Luckfan
    • DrAmine
      Can you provide your account ID?
    • luckfan
      Customer number = 20120530
      Thanks, Luck
Viewing 8 reply threads
  • The topic ‘cannot open ensight of ansys19.0’ is closed to new replies.
