September 27, 2017 at 11:19 amadminAnsys Employee
How can I calculate particle tracking in absolute reference coordinate system when using MRF?
October 17, 2017 at 8:25 amcbhavsarAnsys Employee
Since particle tracking is based on the coordinate system, if Track in Absolute Frame is enabled, Particle tracking can be in the absolute reference coordinate system. Changes are made using the TUI command: define/models/dpm/options/track-in-absolute-frame
- The topic ‘Calculate particle tracking in absolute reference coordinate system when using MRF’ is closed to new replies.
Ansys Innovation Space
- Non-Intersected faces found for matching interface periodic-walls
- Fluent fails with Intel MPI protocol on 2 nodes
- Cyclone (Stairmand) simulation using RSM
- error udf
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
- UDF, Fluent: Access count of iterations for “Steady Statistics”
599
591
555
366
