November 8, 2024 at 1:49 am
jedicker
SubscriberI'm trying to run a parallel Fluent job that spans multiple nodes on a Linux cluster. The job works fine when run on a single node, but a multi-node job fails with the error "unable to run bstrap_proxy on (hostname)." Â
The cluster is running Linux (RHEL 9.4) with Slurm 24.05.  I've tried Ansys 2024R1 and 2023R2. They both fail in the same way.
I strongly suspect the issue is related to Slurm 24.05. Are there any workarounds?
I saw another issue about AnsysEM that provided a patch for the HFSS slurm_srun_wrapper.sh script.  Perhaps a similar issue affects fluent.
December 9, 2024 at 8:32 am
Christian Woiczinski
SubscriberFacing similar problem when trying to run CFX spread over multiple nodes.Â
December 13, 2024 at 4:56 pm
George Karnos
Ansys EmployeeHi,
Please see if the following post helps
Fluent fails with Intel MPI protocol on 2 nodes
5824
