Boolean operation
    • 2020221038
      The software reported an error during the Boolean operation, with the minimum distance being much greater than the tolerance value, but the Boolean operation was displayed as failed.
      Boolean operation failed.  Try adjusting the tolerance value on the  BTOL command to some fraction of the minimum keypoint distance.Model  Size (current problem) 1.963837e+01, current BTOL setting 1.000000e-05, minimum KPT distance 5.918203e-01.
    • Ashish Khemka
      Please see if the following link helps: Boolean Operation Failed
      Ashish Khemka
      Introducing Ansys Assistant a 24/7 AI-powered virtual assistant for active Ansys academic customers.
