TAGGED: #acp-#compositematerials, acp, acp-ansys, acp-compositematerials, acp-pre, mechanical, mesh, meshing
April 2, 2024 at 10:01 pmDaniel ColeSubscriber
I'm working of a composite structure where a top and bottom section come together in its rear region. In reality this will be two composite layups (top/bottom surfaces) which meet in the layup stage of manufacture, creating a region twice the thickness of the individual layups.
I imported a solid model, created shell surfaces, then fully defined the project in ACP (the solid model is of correct dimsions concerning the thickness, and the individual plies are defined in ACP to reflect this).
However, whenever I load up the mesh in static structural I see that the the two surfaces are not meeting at the rear. Is there any way in which I can force the two surfaces to meet within static structural? Further, if I can get the surfaces to meet, how can I define them such that Ansys recognises that they are bonded as a region of 8 plies, not simply 2 layers of 4 plies each which are just in contact with eachother? Would this be contained within contacts?
April 4, 2024 at 12:10 pmAniketForum Moderator
being answered here: /forum/forums/topic/how-to-make-two-meeshed-regions-behave-as-a-solid-body/
will close this one now as duplicate.
-Aniket
- The topic ‘Bonding / merging structures’ is closed to new replies.
- How to apply Compression-only Support?
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- Script Error Code:800a000d
- Elastic limit load, Elastic-plastic limit load
- Image to file in Mechanical is bugged and does not show text
- Element has excessive thickness change, distortion, is turning inside out
1762
635
599
591
366
