March 3, 2020 at 7:24 amFaezWahid95Subscriber
hey guys, i am trying to complete rolling element bearing vibration analysis in explicit dynamics, i have some questions for experts;
1) how to rotate the inner ring and the roller at the same time with presence of frictional contact between both component ?
2) from the 'Analysis Setting', it have 'remote displacement', what is the purpose of that option ?
Here i attached the image of the bearing
March 6, 2020 at 10:33 amajaynsvSubscriber
Hey Faez,
send .wbpz file then I can have a look and suggest you something if possible.Â
March 7, 2020 at 1:17 am
March 7, 2020 at 3:17 amFaezWahid95Subscriber
peteroznewman the model i get directly download fom SKF free CAD .. is that necessary to have that item ?
March 7, 2020 at 3:18 amFaezWahid95Subscriber
how can i get the .wbpz file ? need to convert or what ?? can you whatsapp me to go through detail about my project ?
March 11, 2020 at 10:52 amajaynsvSubscriber
Please use File > Archive to create a .wbpz file. That is how you share ANSYS models.
March 12, 2020 at 12:34 amFaezWahid95Subscriber
ajay0071994 here the link
https://drive.google.com/open?id=12xBbODzaxb0gF8eR3hx4CpkkUjUevQ_Q
March 12, 2020 at 8:48 amajaynsvSubscriber
Hi Faez,
Do these changes and let me know the errors.
1. change the friction coefficient values to 0.1 to 0.2.
2. in connections select the whole circular surface of roller to the inner race and outer race.
3. remove the connections between side faces of the rollers and race.
March 17, 2020 at 7:36 amFaezWahid95Subscriber
sorry sir . I really look forward for you help to solve my problem, may you have a moment to figure out my problem about my this project . a big thanks from me sirÂ
https://drive.google.com/file/d/1jdju7bcBxYqrsoQisSjwnVDaInmLMw14/view?usp=sharing
- The topic ‘Bearing rotation Analysis’ is closed to new replies.
- How to apply Compression-only Support?
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- Script Error Code:800a000d
- Elastic limit load, Elastic-plastic limit load
- Image to file in Mechanical is bugged and does not show text
- Element has excessive thickness change, distortion, is turning inside out
1762
635
599
591
366
