February 12, 2025 at 7:43 pm
rx20729
SubscriberHi,
I have transferred data from a hydrodynamic diffraction system to an upstream static structural system using the hydrodynamic pressure add-on. I am using the static structural system to determine loads within a floating structure (axial loads and bending moments through beams). I would like to represent these loads as RAOs, to show the loading through each beam at each wave frequency and each wave direction. I am wondering whether it is possible to generate these RAOs within Ansys, or will I have to export the data and create these plots myself?
February 17, 2025 at 11:45 am
Shuangxing Du
Ansys EmployeePlease see the discussions in Static Structural with Hydrodynamic Pressure – Beam Loads Represented as RAOs.
Ansys Innovation Space
- How do I get my hands on Ansys Rocky DEM
- convergence issue for transonic flow
- Point exception in erosion calculation
- Errors with multi-connected bodies using AQWA
- Script Error Ansys
933
772
599
591
