February 12, 2020 at 3:28 pm
ATournilhac
SubscriberHi,
I'm currently having an issue to compute the air gap flux density of a synchronous machine using Maxwell. The model have been generated by RMxpert, and I think the cause could be the mesh generation in the band. I've tried to minimize the maximal mesh length but It's not that.
I've observe missing mesh appear when the machine rotate and I think It's the cause. I don't know how to parametrize the band to keep a constant meshing, but I've seen that the parameter "SegAngle" helps.
Maybe anyone of you had the same problem ?
Thanks for your help
Viewing 0 reply threads
- The topic ‘Band Mesh Issue in Synchronous Motor Maxwell model’ is closed to new replies.
