January 11, 2022 at 11:06 amchristian.katsavosSubscriber
Hello, I'm studying the Rigid Dynamics Capabilities of ANSYS and, in particular, how joints work in Rigid Multi Body Simulations.
Reading the ANSYS Mechanical Rigid Body Dynamics Course, Module 3 (Connections/Joints) I came across this slide:
[Image showing a slide from Ansys course notes deleted]
I don't understand what to do in order to have an associative Coordinate system and why it is recommended that all reference CSs be defined as associative.
Sometimes it happens that more than one Reference Coordinate system has an axis defined "by default", but I don't receive any warning about the fact that I'm working on a non-fully associative coordinate System.
Thank you so much for any explanation you will provide me with!
Christian
January 11, 2022 at 11:16 amErik KostsonAnsys Employee
Please do not post images of Ansys course material online - we have removed this screenshot now, but please be aware of this.
I would strongly recommend to ask this question in the ansys learning hub since you can then refer to these points in the slides and the instructors who have developed these (slides/notes) can then hopefully comment on the points you ask in your post above.
All the best
Erik
January 11, 2022 at 12:14 pmchristian.katsavosSubscriberDear Erik Please excuse me for the screenshot I attached to my post.
I'll contact the Learning Hub according to your advice.
Many thanks Christian
January 11, 2022 at 1:18 pmErik KostsonAnsys EmployeeNo worries at all.
Sure the instructors (Ansys Learning Hub) will be able to provide some good feedback with regards to your questions.
All the best for now
Erik
Viewing 3 reply threads- The topic ‘Associative Coordinate Systems’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- Frictional No separation contact
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- Script Error Code:800a000d
- Elastic limit load, Elastic-plastic limit load
- Element has excessive thickness change, distortion, is turning inside out
Top Contributors-
1406
599
591
555
366
