Applying heat on external surface of a cylinder in Rocky
    • f.jalilijamshidian
      Hi. Is it possible to apply constant heat on the external surface of a cylinder (wall) containing particles in Rocky (fluidized bed)?
      Thank you.
    • Lucas Bertollo Baggio
      You can set this heat source in the Fluent .cas file for a 2-way coupled project.
        Thanks Lucas,
        So is it automatically applied in Rocky? Should not I use any other external modules in Rocky?
        I appreciate that.
          You just have to Enable Thermal in Study | Physics. No additional modules required.
          Thank you so much Lucas.
