Ansys Products
Ansys Products
APDL psd error while read the .rst file
    • Hongtian CHEN
      When I did a random vibration analysis, after using the code below to draw the psd graphic in apdl, it works well:
      PSDCOM
      PSDRES,DISP,ABS                     !PSDRES, Lab(DISP/VELO/ACEL), RelKey(REL/ABS/OFF)
      PSDRES,VELO,ABS
      PSDRES,ACEL,ABS
      SOLVE
      FINISH
      /POST26
      STORE,PSD,5
      NSOL,2,NODE0,U,X
      RPSD,3,2,,3,1
      /SHOW,JPEG
      PLVAR,3
      which mean I use /POST26 in the same file, it works well for a spectrum analysis.
      However, when I do the part of solution in a file named "Pipe_3A_Transient_Analysis", and use the command "SAVE" to finish the solution part and save the file:
      PSDCOM
      PSDRES,VELO,ABS
      PSDRES,ACEL,ABS
      SOLVE
      FINISH
      After that, in a new file named "Pipe_4_Post26_TimeHistory", I use the command below to reload the results of  Pipe_3A_Transient_Analysis:
      FINISH
      /CLEAR
      /FILNAME,Pipe_4_Post26_TimeHistory,1
      /TITLE,HAHA
      /REPLOT
      /COM,STRUCTURAL
      /UNITS,SI
      *AFUN,RAD
      PI = 3.14159265354
      RESUME,'Pipe_3A_Transient_Analysis','db','.'
      /POST26
      FILE,'Pipe_3A_Transient_Analysis','rst'
      STORE,PSD,5
      the error occurs, in my opinions, it means the .rst file could not be open successfully.
      Because when I do the same operation using the GUI, after clicking on the "TimeHist Postproc", the second GUI occurs, which corresponds to the command "FILE,'Pipe_3A_Transient_Analysis','rst'.
      However, after that, for a spectrum analysis, there is another GUI:
      which has not a corresponding command to make a choice. I think it is a bug, what do you think, and are there any way to solve this question with an APDL command???
      (if I click OK with the GUI method at this moment, it can enter the TimeHist Postproc module, and the command like STORE,PSD/NSOL,.../ESOL,... works well after that, but I want to just use the APDL command, it seems that only the command /POST26 and FILE,'Pipe_3A_Transient_Analysis','rst' could not enter the TimeHist Postproc module correctly for the spectrum analysis case. )
    • dlooman
      Personally, I try to avoid using the APDL gui for anything PSD related.  It seems you already know the commands.  Just issue them in batch mode and if you want to capture a plot use /show,png.  The gui isn't being maintained, so even if there is a bug, it doesn't matter.
