January 13, 2021 at 9:01 pm
VitZam
SubscriberJanuary 15, 2021 at 1:38 pmGeorge Karnos
Ansys EmployeeHello VitZam,nAre you running on 1 machine (DESKTOP-5MLBFI7)nWhat is the output from opening a DOS command prompt and typing in:nping DESKTOP-5MLBFI7nThe error looks to be coming from Intel MPI.nWhat happens if you change it to use IBM MPI?nBest,nGeorgeJanuary 15, 2021 at 2:51 pmJanuary 15, 2021 at 3:25 pmGeorge Karnos
Ansys EmployeeCan you post a screen shot of the Project page?nWhat is the output from opening a DOS command prompt and typing in:nping -4 DESKTOP-5MLBFI7nnI see that when you ping the machine, it uses IPv6.nI am wondering if this may be interfering. pinging usually returns IPv4.January 15, 2021 at 4:29 pmViewing 4 reply threads- The topic ‘APDL cannot be started’ is closed to new replies.
5734
