August 18, 2022 at 12:28 pm
din_hn
SubscriberI have checked the forums and have not found a viable solution yet. One of the people has the same problem as me under this forum for 'ANSYS Products', but I couldn't understand how they solved it because it seems they are using Linux and I use Windows. Another person with the same problem as me in the forum for 'ANSYS Free Student Softwares' has their posts replied, but I couldn't access it because it denies me even opening the page. My last solution is to make a new post myself.
So...I downloaded ANSYS Free Student Software to learn Workbench and Fluent. Fluent and the other applications work well, and I have no problems opening them except for Workbench alone. Whenever I open the workbench, the same unexpected error comes up no matter what I do.
It loads all the plugins, initializes then instant error.
"Unexpected error: The type initializer for 'Ansys.Core.Expressions.ExpressionEvaluator' threw an exception."
The same error over and over again. How can I get my work done at this rate? Then, whenever I open the 'Show Details' button. This is what comes up.
An unexpected error has occurred: The type initializer for 'Ansys.Core.Expressions.ExpressionEvaluator' threw an exception.
System.MissingMethodException: Method not found: 'System.Collections.Generic.IEnumerable`1 Microsoft.Scripting.Utils.ReflectionUtils.GetCustomAttributes(System.Reflection.Assembly, Boolean)'.
  at IronPython.Runtime.Binding.PythonBinder.DomainManager_AssemblyLoaded(Object sender, AssemblyLoadedEventArgs e)
  at IronPython.Runtime.Binding.PythonBinder..ctor(PythonContext pythonContext, CodeContext context)
  at IronPython.Runtime.PythonContext..ctor(ScriptDomainManager manager, IDictionary`2 options)
--- System.Reflection.TargetInvocationException: Failed to load language 'IronPython 2.7.4': Method not found: 'System.Collections.Generic.IEnumerable`1 Microsoft.Scripting.Utils.ReflectionUtils.GetCustomAttributes(System.Reflection.Assembly, Boolean)'.
  at Microsoft.Scripting.Runtime.LanguageConfiguration.LoadLanguageContext(ScriptDomainManager domainManager, Boolean& alreadyLoaded)
  at Microsoft.Scripting.Runtime.DlrConfiguration.LoadLanguageContext(ScriptDomainManager manager, LanguageConfiguration config)
  at Microsoft.Scripting.Runtime.DlrConfiguration.TryLoadLanguage(ScriptDomainManager manager, AssemblyQualifiedTypeName providerName, LanguageContext& language)
  at Microsoft.Scripting.Runtime.ScriptDomainManager.GetLanguageByTypeName(String providerAssemblyQualifiedTypeName)
  at Microsoft.Scripting.Hosting.ScriptRuntime.GetEngineByTypeName(String assemblyQualifiedTypeName)
  at Ansys.Core.Expressions.ExpressionEvaluator.CreateScriptEngine()
  at Ansys.Core.Expressions.ExpressionEvaluator..cctor()
--- System.TypeInitializationException: The type initializer for 'Ansys.Core.Expressions.ExpressionEvaluator' threw an exception.
  at Ansys.Core.Expressions.ExpressionEvaluator..ctor()
  at Ansys.Core.Expressions.ExpressionManager..ctor()
  at Ansys.ParameterManager.Data.ParameterEvaluator..ctor(ParameterContainer container)
  at Ansys.ParameterManager.Data.ParameterContainer..ctor()
  at Ansys.ParameterManager.Commands.CreateStaticParameterContainerCommand.Execute(IFullContext context)
  at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext(CommandContext subContext, IExecutionEngineCallback tracer)
  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute(IExecutionEngineCallback executionEngine, CommandContext subContext)
  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute(IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions)
--- Ansys.Core.Commands.CommandFailedException: The type initializer for 'Ansys.Core.Expressions.ExpressionEvaluator' threw an exception.
CommandName: Parameters.CreateStaticParameterContainer()
  at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException(Exception e)
  at Ansys.Core.Commands.CommandAsyncResult.Wait(Int32 milliSecondsTimeout, Boolean exitContext)
  at Ansys.Core.DataModel.ProjectSystem.Project.InvokeProjectInitializationCommands(IProtectedContext commandContext)
  at Ansys.Core.DataModel.ProjectSystem.ResetCommand.Execute(IFullContext context)
CommandName: Reset()
  at Ansys.Core.DataModel.ProjectSystem.ResetCommand.InvokeAndWait(IProtectedContext context)
  at Ans.Program.Runtime.Initialize(RuntimeSettings settings)Solutions I tried:
- Reinstalled 5 times to be exact.
- Redownloaded the software from the website and then reinstalled it.
- Restarting my computer.
- Checking my environment paths, and they linked correctly.
All the above solutions were done, and not a single one worked. I am annoyed. I want to contact support but cannot, and it directs me to this because I have the student software. Can someone help me?
August 22, 2022 at 7:32 pm
George Karnos
Ansys EmployeeIf you Open windows file explorer and go to:
%APPDATA%\
You should see a directory named:Â Â Ansys
rename this to Ansys.old.
now try to run.If that doesnt help:
What is the output from opening a DOS cmd prompt and typing in the following and hitting enter:
set -
August 25, 2022 at 2:02 pm
din_hn
SubscriberI tried renaming the directory, which has the same problem mentioned above.
As for the output from running 'set' in cmd, it gives the following prompt:
IRONRUBY_11=C:\Program Files (x86)\IronRuby 1.1\bin
LOCALAPPDATA=C:\Users\User\AppData\Local
LOGONSERVER=\\User
LSTC_LICENSE=Ansys
NUMBER_OF_PROCESSORS=8
OneDrive=C:\Users\User\OneDrive
OS=Windows_NT
Path=C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\110\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\120\Tools\Binn\;C:\Program Files\Microsoft SQL Server\120\Tools\Binn\;C:\Program Files\Microsoft SQL Server\120\DTS\Binn\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;C:\Program Files (x86)\IronRuby 1.1\bin;C:\Program Files\dotnet\;C:\Users\Din_H\AppData\Local\Microsoft\WindowsApps;
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
PROCESSOR_ARCHITECTURE=AMD64
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 158 Stepping 10, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=9e0a
ProgramData=C:\ProgramData
ProgramFiles=C:\Program Files
ProgramFiles(x86)=C:\Program Files (x86)
ProgramW6432=C:\Program Files
PROMPT=$P$G
PSModulePath=C:\Program Files\WindowsPowerShell\Modules;C:\Windows\system32\WindowsPowerShell\v1.0\Modules;C:\Program Files (x86)\Microsoft SQL Server\120\Tools\PowerShell\Modules\
PUBLIC=C:\Users\Public
P_SCHEMA=C:\Program Files\ANSYS Inc\v222\AISOL\CADIntegration\Parasolid\PSchema
SESSIONNAME=Console
SoS_debug_exe=C:\Program Files\ANSYS Inc\v222\optiSLang\sos\sos_console.exe
SoS_exe=C:\Program Files\ANSYS Inc\v222\optiSLang\sos\sos.exe
SoS_install_dir=C:\Program Files\ANSYS Inc\v222\optiSLang\sos
SW_SIM_HYDRA=C:\Program Files\Common Files\SolidWorks Shared\Simulation Worker Agent\
SW_SIM_MPIT=INTELMPI
SW_SIM_TEMP=C:\ProgramData\SOLIDWORKS\SW_net_sim_temp\
SystemDrive=C:
SystemRoot=C:\Windows
TEMP=C:\Users\User\AppData\Local\Temp
TMP=C:\Users\User\AppData\Local\Temp
USERDOMAIN=User
USERDOMAIN_ROAMINGPROFILE=User
USERNAME=User
USERPROFILE=C:\Users\User
windir=C:\Windows -
August 25, 2022 at 2:52 pm
George Karnos
Ansys EmployeeIt could be that IronRuby is interferring.
I would try editing your system PATH to make sure that it starts with c:\Windows\system32
Path=C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\110\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\120\Tools\Binn\;C:\Program Files\Microsoft SQL Server\120\Tools\Binn\;C:\Program Files\Microsoft SQL Server\120\DTS\Binn\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;C:\Program Files (x86)\IronRuby 1.1\bin;C:\Program Files\dotnet\;C:\Users\Din_H\AppData\Local\Microsoft\WindowsApps;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;....etc
Also, if IronRuby is not needed, you can try uninstalling it.
August 25, 2022 at 3:00 pm
din_hn
SubscriberAfter carefully following your suggestions, I edited the path similar to what you have shown, and the error persisted. But after IronRuby was uninstalled, only then did the workbench work properly.
Thank you. It finally works after days of trying.
- The topic ‘ANSYS Workbench Unexpected Error Problem’ is closed to new replies.
5734
