May 24, 2024 at 9:52 am
pmrcl
SubscriberHello,Â
I have recently been given some pre-existing files for Ansys Workbench and Fluent (2023 R2). The day that I had received them, all files were opening and operating correctly. However, when I try and open one of the files since, I get an error message which says 'GuiOperation Open...' through exception during Invoke: Could not find a part of the pathÂ
I also get the same error when I try and open the logs of previous sessions, both from when I initially opened it and the previous person's. All of the Workbench files are opening correctly. The file path that it appears to be looking for, I have been able to follow in file explorer, although the final file appears empty. I have also tried to reset the app data by using %APPDATA% and renaming it to v232_Old and still get the same error.Â
Any advice would be much appreciated.
Best wishes,
May 30, 2024 at 7:25 am
V.P
Ansys EmployeeÂ
Hi Rachael,
Ensure your system meets the minimum hardware requirements listed on the download page for workbench-based simulation tools. Update all drivers. Start a new project in a different workbench file to check if the issue persists, as the model might be corrupted. If the problem continues, try installing a different version of Ansys.Â
- The topic ‘Ansys Workbench failing to open file’ is closed to new replies.
5709
