TAGGED: 1-server, about-license., ansys-license-manager
July 8, 2026 at 9:16 pm
samuel.prieto
SubscriberI would like to know if there is any problem if I change the IP address to which the Ansys server is connected. Currently, our client machines point to the server using its Hostname.The new IP will be static and within a different subnet. Do I need to re-read the license file or update any configuration in the Ansys License Manager after the change?
July 9, 2026 at 12:22 am
Lito
Ansys EmployeeThis might affect access from the client machines since this will be on a different subnet.Â
Try the 'Features in Use' in the Ansys licensince client if you are able to connect and access the license server after the IP change.Â
KB >> License configuration using the Ansys Client Licensing Settings – Ansys Optics
