TAGGED: bearing, mechanical, pivot-error, rotating-shaft
October 22, 2023 at 11:21 am
lutfiantoraihan
SubscriberHi all, I have a simple problem like this.
This is a shaft subjected to a torsion load in the x-direction. The frictionless supports represent the bearing. I recently opened my old archives from R19.2 and it was working fine. However, when I re-run it in 2023 R2, pivot error happened.
I know that this model is not properly constrained, but my questions are:
1) Why was this model working in R19.2?
2) How can I sufficiently represent the bearing support so that it can be solved?
I can provide the .wbpz if needed. Thanks!
October 23, 2023 at 5:15 pm
Gary_S
Ansys Employee-
October 24, 2023 at 12:30 am
lutfiantoraihan
SubscriberHi Gary, thanks for your suggestion. I already tried to set the solver pivot checking to "off", but the error still happened. Any other suggestions?
October 24, 2023 at 12:36 pm
Gary_S
Ansys EmployeeOn the Moment conditions, see if setting the Behavior property to Rigid or Coupled is helpful. (Default is Deformable).
October 25, 2023 at 12:13 am
lutfiantoraihan
SubscriberI have tried to change it into "Coupled", the simulation was solved, but with no deformation at all Gary
October 25, 2023 at 1:00 pm
Gary_S
Ansys EmployeeÂ
 A general procedure for determining why a difference in results for different versions.Â
 – Compare the solver input file (ds.dat) file generated from 19.2 to the solver input file generated from 2023R2.
  This can help narrow down any differences in solver settings etc. – Compare the Solution Information (solve.out) file between verisons. Pay close attention to any differences in Warnings or Notes that might give a clue.Â
 – Can you confirm the results obtained in 19.2 were accurate? Do the reactions match the input? Â
- The topic ‘Ansys R19.2 File Won’t Work in 2023 R2’ is closed to new replies.
5834
