September 27, 2022 at 7:20 am
tongfang.fu
SubscriberHi everyone,
I want to do some NVH analysis for a E motor by flexible Multibody simulation (MBS). Is there any difference between the transient structural package of ANSYS Mechanical and ANSYS Motion? Will it be sufficient if I only use transient structural?
Thanks and BR
September 27, 2022 at 11:15 am
peteroznewman
SubscriberI haven’t used ANSYS Motion, I have used MBS software which used the Recurdyn solver.
NVH = Noise, Vibration, Handling. ANSYS Motion would be preferred for the Handling portion of NVH. ANSYS Mechanical would be preferred for Noise and Vibration. Specifically for the Noise portion, you can use a Harmonic Acoustics analysis. For Vibration, you can use Transient Structural, but the computation times are long and the storage requirements large. You can get answers to many Vibration questions with an order of magnitude less computation using a combination of Modal and Harmonic Response, Random Vibration, or Response Spectrum analyses.
- The topic ‘ANSYS Motion and Mechanical transient structural’ is closed to new replies.
