TAGGED: ansysmechanical, equivalent-stress, Linearized, memory-error
August 23, 2024 at 2:15 pm
flavio.brighenti
SubscriberHi all,
I've been running the same model with small variation in terms of mesh, but never had issues solving it. My problem rises when I create linearized stress solutions (no more than 5 or 6 in various points of the structure). I've noticed that the RAM-usage increases drammatically (up to 100%) to a point where if I close mechanical and then restart it it will take ages to reopen (if it reopens - sometimes it crashes).
I cannot find a solution to this, I've just found out what is causing it thanks to this post https://innovationspace.ansys.com/forum/forums/topic/ansys-2024-takes-forever-to-load/ although not exactly the same reason.
Anyone has a solution?
Thanks! -
September 12, 2024 at 1:21 pm
Gary_S
Ansys EmployeeThis seems similar to a known bug in 2024R1.
There is a Service Pack for 2024R1 (SP3) that may help, although I would use 2024R2.
Note: Even with the 2024R1 (SP3) / 2024R2, it will take time to open the Mechancial the first time.
Allow Mechanical to open the analysis, then make a small change (rename a branch, add a coordinate system etc) then Save, Close and reopen.
Resuming thereafter should then be normal. -
January 22, 2026 at 1:34 pm
shibinkodassery1234
SubscriberHi all,
I started working with my project which consumes about 2 Gb and my current state is (28.5 Gb) mentioned below.
Continuing modeling, saving, and then reopening the file, theRAM usage increases a lot.After solving, it becomes even higher.
The strange part is that even if I clear generated data, the RAM is not released and it keeps on increasing.I am working on Ubuntu (Linux), and I checked this in htop, where I can clearly see the PID and RAM consumption of
ansyswbu.execontinuously increasing.I couldn’t find any way to solve this issue so far.
( 20759 28.5 37551716 /usr/ansys_inc/v241/aisol/CommonFiles/linx64/ansyswbu.exe -DSApplet -nosplash -notabctrl -port 38249 -featureflags meshing.scmeshingtofluidflows;mechanical.material.cylindricalfv;mechanical.lsdynaenhanced2;mechanical.sncurve; -modelcon Model 4 -cap 10115 -cap 10124 ) -
January 22, 2026 at 2:16 pm
Ashish Khemka
Forum ModeratorHello,
This is an old post. Please create a new query/ post.
Ashish Khemka
- The topic ‘Ansys mechanical slow on startup’ is closed to new replies.
5834
