December 3, 2024 at 10:21 pm
jannik.bross
SubscriberHello,
I have a problem with Ansys Mechanical 2024 R1.
Whenever I start Ansys Mechanical, I get the following window:regardless what I pick, mechanical will look like this:
What can I do to fix this?
What I have already tried:- reinstalling Ansys
- rename all v241 folder in Appdata
- reinstall Nvidia graphics driver
- set PATH=C:WINDOWSsystem32;C:WINDOWS;C:WINDOWSSystem32Wbem
- as admin, execute in CMD:
%SYSTEMROOT%\system32\regsvr32.exe  %SYSTEMROOT%\system32\ole32.dll
%SYSTEMROOT%\system32\regsvr32.exe  %SYSTEMROOT%\system32\atl.dll
%SYSTEMROOT%\system32\regsvr32.exe  %SYSTEMROOT%\system32\oleaut32.dll
%SYSTEMROOT%\system32\regsvr32.exe  %SYSTEMROOT%\system32\scrrun.dll
%SYSTEMROOT%\system32\regsvr32.exe  %SYSTEMROOT%\system32\jscript.dll
%SYSTEMROOT%\system32\regsvr32.exe  %SYSTEMROOT%\system32\vbscript.dll- and also as admin, execute in CMD:
regsvr32.exe ole32.dll
regsvr32.exe atl.dll
regsvr32.exe oleaut32.dll
regsvr32.exe scrrun.dll
regsvr32.exe jscript.dll
regsvr32.exe vbscript.dll
- Configure Windows Firewall to allow everything from Ansys
- I have no antivirus program, only the standard microsoft Defender
These where the suggested sollutions from other threads here. Is there anything more I can do?
December 4, 2024 at 9:02 am
Rajeshwari Jadhav
Forum ModeratorHi,
Add this variable in environment variable under system variable,
ANSYS_MECHANICAL_BROWSER=0Â Â Â Â Â Â Â Â Â //is used to avoid starting the newer Browser connection for ACT applications process called DSBrowserService.exe and uses an older exe called ANSYS.ACT.browser.exe
December 4, 2024 at 11:38 am
December 4, 2024 at 12:17 pm
Rajeshwari Jadhav
Forum ModeratorPlease edit the variable it should be like below
variable name: ANSYS_MECHANICAL_BROWSER
variable value: 0
December 4, 2024 at 2:38 pm
December 5, 2024 at 10:28 am
5589
1885
1403
1298
