January 5, 2022 at 12:35 pm
Francoo
SubscriberHi guys,
Recently I am doing simulations of winding loss in a transformer. I am trying to divide each foil turn into 3 parts in vertical direction (1/2 model is used here), which means the 3 parts are parallel connected and a total current of I is flowing inside them. As is shown below, the primary and secondary winding both have 3 foil turns, and each turn consists of 3 parallel parts.
January 6, 2022 at 2:12 pmNKC
Forum ModeratorHi @Francoo The wires that are running parallel for a single conductor in a turn are called strands. it is the number of wires per conductor
Number of parallel branches is the actual parallel paths, if any, in a winding (mostly used for motor windings). this does not represent the conductors running parallel in a single turn as used in your case.
In your case, you can leave it as one.
.Regards Navya
Viewing 1 reply thread- The topic ‘Ansys maxwell winding and coil terminal meaning’ is closed to new replies.
6304
