TAGGED: ansys, Lumerical-FDTD, Lumerical-installation, Lumerical-Mode
January 7, 2022 at 10:16 am
mm_candela
SubscriberI'm a university student. My university got ANSYS license. But I cannot use Lumerical FDTD. When I install ANSYS I cannot access LUMERICAL. Do I need to buy LUMERICAL FDTD separately? How can we purchase Lumerical FDTD separately?
January 7, 2022 at 12:04 pmANSYS_MMadore
Forum ModeratorYour university would need to purchase it separately. If they only have licenses for Mechanical, Fluids and Electronics, it would not include Lumerical access. They need to contact their Ansys Account Manager.
June 3, 2023 at 2:22 pmanindya
SubscriberI have been using Ansys Lumerical FDTD for waveguide designing but for some reason, I need to apply Electrical Voltage to a specific layer of the waveguide to modulate the overall optical properties. Is there any way to apply Electrical Voltages in Lumerical? If I plan to bring the same device to FEEM to connect the voltage supply to it then what are the possible ways to do that. Kindly suggest me a solution.
June 12, 2023 at 4:04 pm
Lito
Ansys Employee@Anindya Bose,
Please post your concerns in the Photonics Category in the Ansys Licensing Forum.Â
October 16, 2023 at 6:01 pmgobong988
SubscriberI would like to evaluate the performance of the MZI-based EO modulator by utilizing Lumerical's interconnect. (The parameter of TW electrode was extracted through HFSS of ANSYS.)
However, in the example provided, there were many explanations for the EYE diagram, but no explanations were found for how to obtain the EO bandwidth.
However, I found a similar file utilizing impulse response in the example of ring modulator, but it didn't work well in my case. (I had a problem where the bandwidth changes every time I change the sample rate)
So I'd like to know how to get EO bandwidth from EO modulator in general.
October 16, 2023 at 6:37 pmLito
Ansys Employee@Kang Donggil,
Please post your concerns in the Photonics Category in the Ansys Licensing Forum. Thank you!
Viewing 4 reply threads- The topic ‘ANSYS LUMERICAL’ is closed to new replies.
