October 6, 2023 at 4:25 am
mousa
SubscriberIt was working since I deployed it two months ago and today I’m not able the licncse manager stopped and when I try to start the license manager it does not run with below messages.
Licensing Interconnect: not running
Licensing Interconnect Monitor: not running
FlexNet Licensing: not running
Then when I run “View licensing Interconnect log I got
-------------------------------------------- NORMAL STARTUP 2023/10/05 16:21:28 ---------------------------------------Ansys Licensing Interconnect version 2022.2.0 (20220519) for winx64. Updated at Ansys Release 2022 R2. Started on 2023/10/05 16:21:28 by SYSTEM@lserver-p3.iltech.iit.edu:winx64 with pid 9504.
                               (C) 2022 ANSYS, Inc. Unauthorized use, distribution, or duplication is prohibited.
                               Built Using FlexNet Publisher v11.16.4.0 build 252457 x64_n6
                               Built Using OpenSSL 1.1.1n 15 Mar 2022
               Please note that entries in this debug log have the following format:
TIMESTAMPÂ Â Â Â Â Â Â Â Â Â Â Â Â ACTIONÂ Â Â Â Â Â Â Â Â Â Â Â Â FEATUREÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â REVISION (BUILD DATE)Â Â Â Â Â Â Â Â Â Â Â Â A/B/C/DÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â W/X/Y/ZÂ Â PID:MPID:APP:USER@HOST:PLATFORM:DISPLAYÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â SOCKET:IPÂ Â Â Â Â Â Â Â Â Â
                               Licenses statistics:
                               A is the number of licenses requested by this ACTION.
                               B is the number of licenses used by this USER.
                               C is the number of licenses used by all users.
                               D is the number of licenses available in the local license pool.
                               License server performance statistics:
                               W is the number of currently connected client applications.
                               X is the maximum number of connected client applications.
                               Y is the unique serial number of this client application.
                               Z is the number of all client applications served by this Licensing Interconnect server.
2023/10/05 16:21:28Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â ANSYSLI_CMD=C:\Program Files\ANSYS Inc\Shared Files\Licensing\winx64\ansysli_server.exe -nodaemon
2023/10/05 16:21:28Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â ANSYSLI_INITIALIZATION_FILE=No initialization file found.
2023/10/05 16:21:28Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â ANSYSLI_MONITOR=C:\Program Files\ANSYS Inc\Shared Files\Licensing\winx64\ansysli_monitor.exe
2023/10/05 16:21:28Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â ANSYSLI_PRODORD_FILE='C:\Program Files\ANSYS Inc\Shared Files\Licensing\prodord\ansysli.prodord.xml'
2023/10/05 16:21:28Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â FLEXLM_LICENSE_FILE='C:\Program Files\ANSYS Inc\Shared Files\Licensing\license_files'
2023/10/05 16:21:28Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â ANSYSLI_PORT=2325
2023/10/05 16:21:28Â Â Â ERRORÂ Â Â Â Â Â Â Â Â Â Â Â Â Â No features to serve, ansyslmd shutting down.
2023/10/05 16:21:28Â Â Â ERRORÂ Â Â Â Â Â Â Â Â Â Â Â Â Â FLEXlm server is down with no available features to serve. Please correct license file and re-start daemons.
2023/10/05 16:21:28Â Â Â ERRORÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Could not start FLEXlm server. Exiting.
2023/10/05 16:21:28Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Listen Socket Created
2023/10/05 16:21:38Â Â Â INFOÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Windows service stopped.
                               -------------------------------------------- NORMAL STARTUP 2023/10/05 16:26:13 ------------------
                               Ansys Licensing Interconnect version 2022.2.0 (20220519) for winx64. Updated at Ansys Release 2022 R2. Started on 2023/10/05 16:26:13 by SYSTEM@lserver-p3.iltech.iit.edu:winx64 with pid 12784.
And the under Diaggnostic à Diplay FlexNet licncse status Igot
lmutil - Copyright (c) 1989-2015 Flexera Software LLC. All Rights Reserved.
Flexible License Manager status on Thu 10/5/2023 23:16
[Detecting lmgrd processes...]
Error getting status: License server machine is down or not responding. (-96,491)
Please I need your help.
Thanks,
October 6, 2023 at 11:03 am
Mrunali Barde
Ansys EmployeeGreetings,Â
Can you please check if the updated license file is present on the Ansys license server? Can you also confirm the expiry date and server details?
- The topic ‘Ansys License manager it does not start’ is closed to new replies.
5804
