April 9, 2024 at 1:28 am
kyle.baylous
SubscriberHello,
I have been running LS-Dyna using HPC resources for the past year without issue and most recently ran a job in the beginning of February using version 2023 R1. However, I am now trying to run LS-Dyna again after a couple months and ran into this issue today:
After upgrading the license server to the 2024 R1 version in addition to upgrading the Fluid/Structures package on the HPC cluster to the 2024 R1 version, I cannot seem to fix this issue despite the license server running well with ample licenses to use.
Please advise how to proceed, thanks.
April 10, 2024 at 10:13 am
Mrunali Barde
Ansys EmployeeHello Kyle,Â
Are you using the student version or academic/commercial?
Can you please check if you have the license file in case you are using an academic or commercial version?-
April 10, 2024 at 5:22 pm
kyle.baylous
SubscriberHi Mrunali,
I am using an academic version of the software as I work in a research group collaborating with ANSYS. This error is specific to LS-Dyna, since other programs (ex: Fluent) run without issue.
April 10, 2024 at 6:02 pm
Mrunali Barde
Ansys EmployeeKyle,Â
Can you please clarify if this is LSTC LS-dyna or Ansys LS-DYNA?
In case it is Ansys LS-DYNA, can you please try to install a service pack for Ansys 2024 R1 and check?-
April 10, 2024 at 6:18 pm
kyle.baylous
It is Ansys LS-Dyna, and I actually did install the new Ansys 2024 R1 package from the download portal yesterday and I am still facing the same issue that I had when I was using the 2023 package regarding insufficent dyna licenses. Here is an image showing the execuation when it was working a couple months ago without issue:
April 11, 2024 at 8:37 pm
kyle.baylous
I tried installing the service pack for ANSYS 2024 R1 but the problem is not resolved. How should the service pack be installed? Should it be installed within the same directory as the original 2024 R1 package?
- The topic ‘ANSYS License Manager Error – Insufficient FNP License Count’ is closed to new replies.
5704
1891
1419
