June 2, 2024 at 3:31 am
chinazyq
SubscriberANS_LogErrorMessage: Caption: ANSYS LICENSE MANAGER ERROR Â Error: No FlexNet Publisher (FNP) license found for feature HPC Parallel.
I met the problem when I use chemkin. I don't know why.
June 3, 2024 at 1:33 pm
Mrunali Barde
Ansys EmployeeHello Chinazyq,Â
Are you using Students Version or Academic?Â
In case you have installed Students versions, can you check if you can solve using 4 or fewer cores/processes?Â
If you have installed the Academic version, can you please confirm if you have as expected licenses as well?Wishes,Â
Mrunali.-
June 3, 2024 at 3:25 pm
chinazyq
SubscriberDear Mrunali Barde,
Thanks for your reply!
I have installed students version, just this one: https://www.ansys.com/zh-cn/academic/students/ansys-student. Could you tell me how to use 4 or fewer cores/processes? Much thanks!
Hope to hear from you soon!
Wishes,
Chinazyq.
July 4, 2024 at 9:37 am
Shane Workman
SubscriberThere is a problem with the Ansys client licensing application on the client machine. This occurs when you open an earlier version of Lumerical on the client system and then launch the current version, 2024 R1, before the "ansycl.exe" program is terminated/shutdown. Please refer to our knowledge base for specifics on how to address the issue.
July 8, 2024 at 5:42 pm
chinazyq
SubscriberHowever, it's my first time to install ansys...
- The topic ‘Ansys Licence 2024 R1 Problem’ is closed to new replies.
5664
1890
1414
1304
