Photonics
Photonics
Ansys Insight: Simulating hollow or coated objects with mesh order
    • kyle.johnson
      The simplest way to generate a hollow object or an object with a coated core (core-shell) is to add two solid concentric objects which overlap in the central region, and set the mesh order of the objects appropriately.
      The mesh order is a property which can either be set from the material database, or in the object properties. In regions where several objects overlap, the material with a smaller mesh order number will take priority. For more information about setting the mesh order property, see this page:
      https://kb.lumerical.com/en/index.html?materials_mesh_order_optical.html
      A common example is a coated spherical nanoparticle. To create this, you can add two concentric sphere objects centered at the same location. If the core object with a smaller radius has a mesh order of 1, and the coating object with a larger radius has the default mesh order of 2, then the core material will included in the simulation.
Viewing 0 reply threads
  • The topic ‘Ansys Insight: Simulating hollow or coated objects with mesh order’ is closed to new replies.
