May 4, 2025 at 5:03 pm
Hasan
SubscriberNew to this and learning reduced errors but still have this problem while setting valve inputs. A spark ingnition two valve enigne. Probably other errors too, there is a gap in the CAD model between the valve seat and the valve face of 0.5 mm. In the inputs IÂ Â Exceeded limit of 500 iterations, please check boundary condition settings.
Ignoring update of min_lift because it is currently a Workbench parameter.
It must only be updated from Workbench. Â -
May 4, 2025 at 5:05 pm
May 4, 2025 at 5:17 pm
Hasan
SubscriberEverytime I enter seat_exhaust and Exhaust_valve_near_seat_surface in the bottom left seletion, the latter disappears once I select Apply and then save, as shown above.Â
May 4, 2025 at 5:36 pm
Ansys Innovation Space
- Unable to attach geometry 2024 R2
- [SpaceClaim] STEP file size using Converter.exe
- How to do the snap fit insertion FEA?
- PMI Product manufacturing information in SpaceClaim/Discovery modeling
- PlugIn Error: Failed to import assembly from SpaceClaim. The object is deleted.
- License issues 2025 R1
971
857
830
777
